Is SPI supported natively under CYCLONE IV or do I have to bit-bang in order to get it to work with SPI peripherals.
Also how many LVDS receives does the CYCLONE IV have on the EP4CE6 TQFP ? I need 16 LVDS recieves @ 480 Mbps for a CMOS area scan sensor data and spi to control it.Link Copied
For the number of LVDS channels supported, you can refer to the device overview chapter of CIV device handbook.
Chapter 9 of the embedded peripherals ip user guide (https://www.altera.com/literature/ug/ug_embedded_ip.pdf) covers Altera's SPI peripheral. This will work in Cyclone IV. That should allow you to do something a little better than bit-banging.
As for LVDS - have a look through the cyclone iv device datasheet (https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/cyclone-iv/cyiv-53001.pdf). 480Mbps is quite punchy - is that DDR? Look at table 1-36 on page 1-32. This covers the LVDS data rates you can expect to achieve with Cyclone IV. Cheers, Alex
