21602 Discussions
SRAM DS2064 into a CPLD
Is it a good idea to implement a SRAM DS2064 (8 bit x 8k) into a CPLD?
After a lot of internet research, I was unable to find a VDHL code for it.
I just attached the DS2064 for reference.
Thanks!
Why would you want to do that?
FPGAs (most all) have internal block RAMs that could implement that storage in about 4-8 BRAMs. CPLDs usually have no internal block RAM, so you'd have to implement as logic.
If "CPLD" is used as a generic term including FPGAs like MAX10, you can implement a similar RAM in it. Consider that due to the synchronous architecture of FPGA block RAM you can't exactly model the behavior of an asynchronous SRAM. Depends on the application if this matters.
Ok, thanks for the info.
I always used CPLD only for logic, not for memory.
