21597 Discussions
SRAM controller in SOPC buil
Actually my project contains ISSI SRAM 512x16 bit. On my board there are two of these cascaded. While testing, I used the memtest code given in NIOS IDE. My hardware image contained NIOS processor, JTAG, onchip memory, tristate bridge and IDT controller (which I found having similar timing as my ISSI SRAM). The test was successful. My main confusion arose, when I probed the IC with CRO. I found that even when I had downloaded only sof file, there were some periodic pattern on pins of IC. Is it that controller in SOPC gives some periodic signals out? As I had expected no signal on pins till there was no software run.
Saransh
Where is the NIOS processor set to boot from? How do you know it's not running "code". It may be random junk.
Jake
NIOS processor is set to boot from onchip memory. I wanted to confirm whether the controller of SRAM keeps on sending some set pattern on its pins, even when software code is not running?
