Programmable Devices
21607 Discussions
SRAM model Generation
Hello
I have a NIOSII system as follow :
EPCS controller
CPU - tristate-Bridge - sram_ctrl_v00
+ some other bits
my SRAM is external to the FPGA. So I have created a controller sram_ctrl_v00
my sram_ctrl_v00 is an Avalon Memory Mapped Tri state Slave, describe in sram_ctrl_v00.tcl.
I found a model of the sram (in the enclosed zip file).
I don't really know how to include the model so it can be used with modelsim. (is it during create custom component ?...)
When I use eclipse , if I set all my code in SRAM , it will never generate the hex file associated with the SRAM (mem_init install or mem_init_generate). I would expect sram_ctrl_v00.hex
Can somebody help please ?
Ben
Hello ,
Please I am facing the same problem can you give me some advice on interfacing external memory:
I wrote a memory model+testbench+controller
How should I move forward?
I would appreciate any advice...
Hello
The model need to be included in the file that represent your NIOS (at the bottom of the file).
You will find locations where you can include your code :
-- <Altera_Note>.....
The code will not be removed when you re generate your NIOS II system.
This is the idea.
To check my design , I had no time to perform what is described above, but this is the philosophy. Instead , I have used the internal memory under Modelsim , and use SDRAM in the real product.
This was to be able to check a full design (NIOS + Logic) together.
Also , you will have to set the NIOS II software/BSP (under Eclipse) to generate the correct file for SDRAM or Internal Mem.
Ben
Hi ben,
I also need to integrate a custom memory in my prjoject. But I don't have idea how the memory controller should look like. I already implemented the model and testbench for Cypress 1024x8 Bit memory.
Can you please share me a piece of code to get an overview ?
What is the difference between the following code and the real sar controller?
--- Quote Start ---
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.numeric_std.all;
entity sram1024kx8 is
port (A : in Std_logic_vector(19 downto 0);
D : inout Std_logic_vector(7 downto 0);
nCE : in std_logic;
nCE2 : in std_logic;
nWE : in std_logic;
nOE : in Std_logic);
end;
architecture Behaviour of sram1024kx8 is
subtype Byte is Std_logic_vector(7 downto 0);
type Mem is array (0 to 1048576 ) of byte;
signal Memory: Mem := (others => Byte'(others=>'U'));
begin
process(A, D, nCE, nCE2, nWE, nOE)
begin
D <= (others => 'Z');
if nCE='0' and nCE2='0' then
if nOE = '0' then -- Read operation
D <= Memory(To_Integer(unsigned(A))) after 10 ns;
elsif nWE = '0' then -- Write operation
Memory(To_Integer(unsigned(A))) <= D;
end if;
end if;
end process;
end;
--- Quote End ---
Please I can't get the relationship between the both I thought it was enough ?
Do you have an example so that I could based on this ?
