21611 Discussions
Sequencial protocol comunication
Hi dears, im new in this forum, and no so far with fpga knowledge.
But ok im trying to learn, i post an experiment i want to comunicate with external component that have:
16 bit address/command
reset signal
chip select signal
and ahother 2 bits this doesnt matter. That i do work and work well... but i think that i dont are in the correct way... i have the feeling that could be more easy or "efficient"
this is my principal verilog:
module video_controller (input clock ,input start ,input color_in, input x, input y, input h, input w,output reg data,output reg latches,output finish,output color_in_next, output reg rst); reg i_counter=0; // cs_rd_wr_rs localparam StartCmd=4'b0101; localparam EndCmd=4'b1111; localparam StartIdx=4'b0100; localparam EndIdx=4'b1110; reg init = 1'b1; always@(posedge clock && init) begin i_counter<=i_counter+1; //if(i_counter>7000)i_counter<=0; case (i_counter) 10 :rst=1'b0; 1000 :rst=1'b1; 1010 :latches=StartIdx; 1020 :data=8'h01; 1030 :latches=EndIdx; 2000 :latches=StartIdx; 2010 :data=8'h01; 2020 :latches=EndIdx; 3000 :latches=StartIdx; 3010 :data=8'h01; 3020 :latches=EndIdx; 4000 :latches=StartIdx; 4010 :data=8'he0; 4020 :latches=EndIdx; 5000 :latches=StartCmd; 5010 :data=8'h01; 5020 :latches=EndCmd; 6000 :latches=StartIdx; 6010 :data=8'he0; 6020 :latches=EndIdx; 6030 :latches=StartCmd; 6040 :data=8'h03; 6050 :latches=EndCmd; 6050 :latches=StartIdx; 6060 :data=8'hb0; 6070 :latches=EndIdx; 6080 :latches=StartCmd; 6090 :data=8'h08; 6100 :latches=EndCmd; 6110 :latches=StartCmd; 6120 :data=8'h80; 6130 :latches=EndCmd; 6140 :latches=StartCmd; 6150 :data=8'h03; 6160 :latches=EndCmd; 6170 :latches=StartCmd; 6180 :data=8'h1f; 6190 :latches=EndCmd; 6200 :latches=StartCmd; 6210 :data=8'h01; 6220 :latches=EndCmd; 6230 :latches=StartCmd; 6240 :data=8'hdf; 6250 :latches=EndCmd; 6260 :latches=StartCmd; 6270 :data=8'h00; 6280 :latches=EndCmd; 6290 :latches=StartIdx;// PIXEL DATA INTERFACE 6300 :data=8'hF0; 6310 :latches=EndIdx; 6320 :latches=StartCmd; 6330 :data=8'h3; 6340 :latches=EndCmd; 6350 :latches=StartIdx;// PIXEL FORMAT 6360 :data=8'h3a; 6370 :latches=EndIdx; 6380 :latches=StartCmd; 6390 :data=8'h50; 6400 :latches=EndCmd; 6410 :latches=StartIdx;//SET PCLK freq=33.26MHz 6420 :data=8'he6; 6430 :latches=EndIdx; 6440 :latches=StartCmd; 6450 :data=8'hff; 6460 :latches=EndCmd; 6470 :latches=StartCmd; 6480 :data=8'hff; 6490 :latches=EndCmd; 6500 :latches=StartCmd; 6510 :data=8'hff; 6520 :latches=EndCmd; 6530 :latches=StartIdx;//SET HBP, HFP 6540 :data=8'hb4; 6550 :latches=EndIdx; 6560 :latches=StartCmd; 6570 :data=8'h20; 6580 :latches=EndCmd; 6590 :latches=StartCmd; 6600 :data=8'haf; 6610 :latches=EndCmd; 6620 :latches=StartCmd; 6630 :data=8'h00; 6640 :latches=EndCmd; 6650 :latches=StartCmd; 6660 :data=8'ha3; 6670 :latches=EndCmd; 6680 :latches=StartCmd; 6690 :data=8'h07; 6700 :latches=EndCmd; 6710 :latches=StartCmd; 6720 :data=8'h00; 6730 :latches=EndCmd; 6740 :latches=StartCmd; 6750 :data=8'h00; 6760 :latches=EndCmd; 6770 :latches=StartCmd; 6780 :data=8'h00; 6790 :latches=EndCmd; endcase end endmodule
And the same code in C is
void TFT_SSD1963_8bit_Set_Index(uint8_t index) { CS_RESET(); RD_SET(); RS_RESET(); DATA_PORT(index); WR_RESET(); WR_SET(); CS_SET(); } void TFT_SSD1963YT_8bit_Write_Command(uint8_t command) { CS_RESET(); RD_SET(); RS_SET(); DATA_PORT(command); WR_RESET(); WR_SET(); CS_SET(); } RST_SET(); TFT_SSD1963_8bit_Set_Index(0x01); //Software Reset for(i=0;i<0x80000;i++){} TFT_SSD1963_8bit_Set_Index(0x01); for(i=0;i<0x80000;i++){} TFT_SSD1963_8bit_Set_Index(0x01); for(i=0;i<0x80000;i++){} TFT_SSD1963_8bit_Set_Index(0xe0); //START PLL for(i=0;i<0x80000;i++){} TFT_SSD1963YT_8bit_Write_Command(0x01); for(i=0;i<35000;i++){} // Wait 100us to let the PLL stable TFT_SSD1963_8bit_Set_Index(0xe0);//LOCK PLL TFT_SSD1963YT_8bit_Write_Command(0x03); TFT_SSD1963_8bit_Set_Index(0xb0); //SET LCD MODE SET TFT 18Bits MODE TFT_SSD1963YT_8bit_Write_Command(0x08); //SET TFT MODE & hsync+Vsync+DEN //MODE TFT_SSD1963YT_8bit_Write_Command(0x80); //SET TFT MODE & hsync+Vsync+DEN //MODE TFT_SSD1963YT_8bit_Write_Command(0x03); //SET horizontal size //HightByte TFT_SSD1963YT_8bit_Write_Command(0x1f); //SET horizontal size //LowByte TFT_SSD1963YT_8bit_Write_Command(0x01); //SET vertical size //HightByte TFT_SSD1963YT_8bit_Write_Command(0xdf); //SET vertical size LowByte TFT_SSD1963YT_8bit_Write_Command(0x00); //SET even/odd line RGB seq.=RGB TFT_SSD1963_8bit_Set_Index(0xF0);// PIXEL DATA INTERFACE TFT_SSD1963YT_8bit_Write_Command(0x3); TFT_SSD1963_8bit_Set_Index(0x3A);// PIXEL FORMAT TFT_SSD1963YT_8bit_Write_Command(0x50); TFT_SSD1963_8bit_Set_Index(0xe6); //SET PCLK freq=33.26MHz TFT_SSD1963YT_8bit_Write_Command(0xFF);//REFRESCO AL MAXIMO TFT_SSD1963YT_8bit_Write_Command(0xFF);//REFRESCO AL MAXIMO TFT_SSD1963YT_8bit_Write_Command(0xFF);//REFRESCO AL MAXIMO TFT_SSD1963_8bit_Set_Index(0xb4); //SET HBP, HFP TFT_SSD1963YT_8bit_Write_Command(0x20); //SET HSYNC TFT_SSD1963YT_8bit_Write_Command(0xaf); TFT_SSD1963YT_8bit_Write_Command(0x00); //SET HBP TFT_SSD1963YT_8bit_Write_Command(0xa3); TFT_SSD1963YT_8bit_Write_Command(0x07);//SET VBP TFT_SSD1963YT_8bit_Write_Command(0x00);//SET Hsync pulse start position TFT_SSD1963YT_8bit_Write_Command(0x00); TFT_SSD1963YT_8bit_Write_Command(0x00);//SET Hsync pulse subpixel start //position TFT_SSD1963_8bit_Set_Index(0xb6);//SET VBP, VFP TFT_SSD1963YT_8bit_Write_Command(0x01);//SET Vsync TFT_SSD1963YT_8bit_Write_Command(0xef); TFT_SSD1963YT_8bit_Write_Command(0x00);//SET VBP TFT_SSD1963YT_8bit_Write_Command(0x04); TFT_SSD1963YT_8bit_Write_Command(0x01);//SET Vsync pulse TFT_SSD1963YT_8bit_Write_Command(0x00);//SET Vsync pulse start position TFT_SSD1963YT_8bit_Write_Command(0xff);
This are the gates...
https://alteraforum.com/forum/attachment.php?attachmentid=13596&stc=1
This are the squematic
https://alteraforum.com/forum/attachment.php?attachmentid=13597&stc=1
And this is my result (seems to works good)
https://alteraforum.com/forum/attachment.php?attachmentid=13598&stc=1
What do you think? Anyone have and advice for me? i am in the correct way?
Note quite sure what you want? if it works, whats the problem?
Are you wanting us to comment on the (poor) coding style?
"Are you wanting us to comment on the (poor) coding style", yes i really want a comment or an idea about my poor coding style or another way to doing that.
Some Points:
1. Add comments to your code - comments should explain WHY you do something, not WHAT.
2. Sort the ports out - 1 port per line
3. One big case statement - why?
you are right this are a little part of the code with coments
module video_controller ( input clock , input start , //not used per now input color_in, //not used per now input x, //not used per now input y, //not used per now input h, //not used per now input w, //not used per now output reg data, output reg latches, output finish, //not used per now output color_in_next, //not used per now output reg rst ); reg i_counter=0; //start i_counter=0 localparam StartCmd=4'b0101; localparam EndCmd=4'b1111; localparam StartIdx=4'b0100; localparam EndIdx=4'b1110; reg init = 1'b1; //variable to start sequencial always@(posedge clock && init) begin i_counter<=i_counter+1; //increment on posedge clock //data 8 bits of data bus to external device //latches are the clock,cs,write and read this ar params of the external device case (i_counter) 10 :rst=1'b0; //1 step - reset device 1000 :rst=1'b1; //2 step - reset device 1010 :latches=StartIdx; //3 step - latches = 0100 1020 :data=8'h01; //4 step - send to device = h01 1030 :latches=EndIdx; //5 step - latches = 1110 & WAIT of 1000 2000 :latches=StartIdx; //3 step - latches = 0100 2010 :data=8'h01; //4 step - send to device = h01 2020 :latches=EndIdx; //5 step - latches = 1110 & WAIT of 1000 3000 :latches=StartIdx; //3 step - latches = 0100 3010 :data=8'h01; //4 step - send to device = h01 3020 :latches=EndIdx; //5 step - latches = 1110 4000 :latches=StartIdx; //3 step - latches = 0100 4010 :data=8'he0; //4 step - send to device = he0 4020 :latches=EndIdx; //5 step - latches = 1110 & WAIT of 1000 5000 :latches=StartCmd; //3 step - latches = 0101 5010 :data=8'h01; //4 step - send to device = h01 5020 :latches=EndCmd; //5 step - latches = 1111 & WAIT of 1000 6000 :latches=StartIdx; //3 step - latches = 0100 6010 :data=8'he0; //4 step - send to device = he0 6020 :latches=EndIdx; //5 step - latches = 1110 6030 :latches=StartCmd; //3 step - latches = 0101 6040 :data=8'h03; //4 step - send to device = h03 6050 :latches=EndCmd; //5 step - latches = 1111
One big case statement why?.
Because i need a sequential and timming excecution on ports
Best Regards
