Programmable Devices
21615 Discussions
Serial Flash Loader Megafunction (SFL) - how to
I want to include SFL Megafunction in my project.
I have created a new project for Cyclone II (EP2C20Q240) and pasted code written by fvm (http://www.alteraforum.com/forum/showthread.php?t=2472&page=2&highlight=sfl+megafunction) (thanks!).
LIBRARY ieee; USE ieee.std_logic_1164.all; ENTITY sfl_3c16 IS END sfl_3c16; ARCHITECTURE RTL OF sfl_3c16 IS COMPONENT sfl PORT ( noe_in : IN STD_LOGIC ); END COMPONENT; BEGIN sfl_inst : sfl PORT MAP ( noe_in => '0' ); END RTL; Of course I have generated sfl using MegaWizard Plug-in Manager.
Next I ran Programmer and configured Cyclone II. After that I click right mouse button on first row and select Attach Flash Device and select EPCS.
Checked Erase checkbox in the EPCS4 row. Unchecked Program/Configure checkbox in FPGA row (because FPGA was configured earlier).
http://urbanowski.pl/error.jpg
I choosed Start and got an error: Flash Loader IP not loaded on device 1. Operation Failed.
What am I doing wrong?
When I choose default SFL (sfl_ep2c20.sof) from quartus\common\devinfo\programmer directory everything works fine! So I think that there is an error in vhdl code or maybe I have not checked any necessary options in quartus (I am a newbie ;)).
Can you see, that the SFL megafunction has been actually compiled to the configured design? It must be present e. g. in the Quartus hierarchy view. Generally, I experienced some cases, where the SFL wasn't compatible with other design elements (pin usage or I/O voltage assignment) or where it wasn't working correctly, that means not accessing the AS device. But the SFL has been always accessible by the JTAG programmer.
Yes, megafunction has been compiled. Look at the screenshot:
http://urbanowski.pl/error2.jpg
I have a "clean" design, without any pins or I/O assignments.
This design should be basically equivalent to EPC2 factory SFL design.
Although my example originates from EPC3, I have also used it with
Cyclone II without problem. There may be a problem, that an unconfigured
AS memory device is interfering with JTAG. The Quartus programmer
has an option "Halt on-chip configuration controller" to avoid this situation.
As a (really trivial) reason, the sof-file selected in Quartus programmer may be
different from the current compiled design.
--- Quote Start ---
--- Quote End ---
OK. But when I am configuring FPGA with "factory default" sfl (quartus/common/devinfo/programmer/sfl_ep2c20.sof) everything is ok and I have access to EPCS4 (without checking option "Halt on-chip configuration controller"). I think there is a "stupid" error in my project. But I will try to enable that option.
--- Quote Start ---
--- Quote End ---
No way ;)
I have no further explanation, except there may be a Quartus V8 problem.
I did all tests with Quartus V7.2
I have tried Quartus 7.2 SP3, Quartus 8.0 SP1 and Quartus 8.1 without any success :(
I have solved my problem. I have checked "Enable INIT_DONE output" and "Enable device-wide output enable (DEV_OE)" [Assignments > Device... > Device and Pin Options > General] and SFL Megafunction is working now :)
Good, that you succeeded, but strange anyway. I've been using SFL without these pin options. I guess, it's rather
a problem with AS related pin options. But I remember, that I experienced a mysterious failure of SFL in one
design. I'll check the effect of pin options ocasionally, when inplementing another design utilizing SFL.
--- Quote Start ---
I guess, it's rather a problem with AS related pin options.
--- Quote End ---
You were right. The operation of programming EPCS4 was not sometimes successful with "Enable INIT_DONE output" and "Enable device-wide output enable (DEV_OE)" options checked. So I have been testing other options. I have switched the option "Reserve all unused pins: As output driving ground" to "As input tri-stated" and my design is 100% stable and functional now. Operations of programming, verifing or erasing EPCS4 are always OK.
"Enable INIT_DONE output" and "Enable device-wide output enable (DEV_OE)" options are not necessary.
Thank FvM for your help!
