ladies and gentlemen,
I want to implements a SPI interface between an FPGA and a H brigde for DC-Motors. The Nios II serial peripheral interface (SPI) module is an Altera SOPC Builder library component included in the Nios development kit. can someone help me how to iplements SPI using Nios II? thank you karimLink Copied
Hi Karim,
Have you had a look on the Nios Forum for SPI related threads? There are discussions and examples of code for using SPI. I'd suggest searching that forum and also reading the Altera document on the SPI peripheral. It depends on the device your NIOS is communicating with, but it should be fairly straightforward. Cheers Sharkybaba- Mark as New
thank you sharkybaba
