21611 Discussions
Sharing PLL - using SOPC Builder
Hello folks,
I have instantiated 3 DDR3 Memory controllers into the Nios II CPU and each memory controller uses its own PLL (3 PLL's used). As all the memory controllers operate on the same clock frequency, I want to share the PLL resources.
In the manual from Altera - emi_tut_ddr.pdf, they mention to 'select' the option - use clocks from another controller in the Controller Settings tab of the MegaFunction Wizard ALTMEMPHY for the DDR3 SDRAM. I have selected this option for 2 of my memory controllers
However, after generating the SOPC, I still end up using 3 PLL's for the 3 memory controllers :confused:. What is it that I am doing wrong? Is there any way to share the PLL resources as I just want to use 1 PLL if possible.
Any help would be great!
hi, did you find a solution for your probleme? I have the same...
Thank you
Unfortunately, I still have the problem and I don't know what to do!
Hi I found the solution, it's in this file http://www.altera.co.jp/literature/hb/external-memory/emi_tut_qdr.pdf
you have juste to follow the instractions and it works ...
good luck
Are you using the ALTMEMPHY or UniPHY?
Uniphy, but here is an example of three ddr3 ALTMEMPHY sharig pll/dll :
http://www.altera.com/support/examples/vhdl/vhd-stratix-iv-3-ddr3-altmemphy-dll-pll.html
Hey,
Thanks for the link. I think I already had a looked into this example sometime back. Anyway, I tried it again - Downloaded the project, Restored it and Compiled.
result: "The compilation report says 3 PLL's and 1 DLL used!"
So, I guess only the DLL's were shared. What about the PLL's? I want to know whether there is any possibility of sharing the PLL's so that I use just 1 PLL for 3 DDR3 Memory Controllers w.r.t this example.
