Hi!
I am just trying to generate a shift register in verilog. Quartus 9.1sp2 provides me with an error message I don't understand: "Error (10198): Verilog HDL error at stratixIII_3sl150_dev_niosII_standard.v(246): part-select direction is opposite from prefix index direction" Any clues what I am doing wrong? Code: (Line marked with * is where the error is reported)
//number of FFs
`define WIDTH 10
module sreg(
<snip>
// Generate Signal
reg genreg;
always @(posedge clk or negedge reset_n)
begin
if (!reset_n)
genreg = load_genreg;
else
genreg = ~genreg;
end
// Shift register
reg sreg;
always @(posedge clk)
begin
* sreg = sreg;
sreg = genreg;
end
assign out = sreg;
endmodule
Assuming you copied and pasted directly from you HDL file you spelled "WIDTH" wrong on the right side. I don't use defined values myself so I don't know how verilog is supposed to behave in that case.
Gratulations for looking sharp! I didn't see it. Apparently, the Verilog preprocessor is assuming a value of zero for unknown symbols instead of complaining about a missing definition.
:oops: Yes, you are right. Seems that the error message misled me slightly. Thanks!
I tend to use local parameters for things like this, the same typo if it was a localparam I think would have resulted in a more meaningful error message. I don't know the pros and cons for one way or the other but I think we now know a con when using 'define :)
Anyway what that message means is that you had [-2:0] as the subscripts on the left side as a result of this verilog quirk.
