21615 Discussions
Signal Tap II analyzer error
I am using Quartus II for Cyclone II device. I have USB blaster for JTAG connection.
I am trying to use signal tap II analyzer. When I try to recompile the file, after setting the instance and trigger conditions it is giving the following error messages
Error: Node instance "instance_1" instantiated with unknown parameter "SLD_ATTRIBUTE_MEM_MODE"
Error: Can't elaborate inferred hierarchy "sld_signaltap:instance_1"
Error: Quartus II Analysis & Synthesis was unsuccessful. 2 errors, 3 warnings
Error: Peak virtual memory: 175 megabytes
Error: Processing ended: Tue Apr 28 16:55:03 2009
Error: Elapsed time: 00:00:06
Error: Total CPU time (on all processors): 00:00:04
Error: Quartus II Full Compilation was unsuccessful. 4 errors, 3 warnings
I am pretty new to FPGA design. Pleae help me out with this issue.
--- Quote Start ---
--- Quote End ---
which Quartus Version did you use and how did you setup the signaltap file ?
Kind regards
GPK
Thanks a lot for replying Pletz.
I found the mistake. I had installed both quartus 7.1 and 8.0. Signal tap II analyzer was pointing to 7.1 but i had compiled my program in quartus 8.0.
--- Quote Start ---
--- Quote End ---
fine that you found the root cause. I expected something like that. Switching between
Quartus versions requires always signaltap files, generated by the corresponding Quartus version.
Kind regards
GPK
hi gadeepu
how you deal with the problem?
--- Quote Start ---
hi gadeepu
--- Quote End ---
you have to use the signaltap version of the Quartus version you used for P&R.
Kind regards
GPK
