21618 Discussions
Signal has no source
Hi All!
When i compile the following code: (Quartus)
entity ISA is
port
--from ISA to CPU
(AEN_IN,IOR_IN,IOW_IN :inout std_logic;
ADDR_IN : inout std_logic_vector(10 downto 0);
DATA_IN :inout std_logic_vector(7 downto 0);
--from CPU to ISA
DATA_OUT :inout std_logic_vector(7 downto 0) );
end ISA;
architecture arch of ISA is
signal DATA_BUF : std_logic_vector(7 downto 0);
begin
process(IOW_IN,IOR_IN)
begin
--write operation
if IOW_IN'event and IOW_IN = '0' then
if ADDR_IN = B"01000011000" AND AEN_IN ='0' then
DATA_BUF <= DATA_IN ;
DATA_OUT <= DATA_BUF ;
else
DATA_OUT <= "ZZZZZZZZ";
end if;
end if;
--read operation
if IOR_IN'event and IOR_IN = '0' then
DATA_IN <= DATA_OUT;
end if;
end if;
end process;
end arch;
I get warnings:
Warning: The bidir "AEN_IN" has no source; inserted an always disabled tri-state buffer.
Warning: The bidir "IOR_IN" has no source; inserted an always disabled tri-state buffer.
Warning: The bidir "IOW_IN" has no source; inserted an always disabled tri-state buffer.
Warning: The bidir "ADDR_IN[0]" has no source; inserted an always disabled tri-state buffer.
Warning: The bidir "ADDR_IN[1]" has no source; inserted an always disabled tri-state buffer.
Warning: The bidir "ADDR_IN[2]" has no source; inserted an always disabled tri-state buffer.
Warning: The bidir "ADDR_IN[3]" has no source; inserted an always disabled tri-state buffer.
Warning: The bidir "ADDR_IN[4]" has no source; inserted an always disabled tri-state buffer.
Warning: The bidir "ADDR_IN[5]" has no source; inserted an always disabled tri-state buffer.
Warning: The bidir "ADDR_IN[6]" has no source; inserted an always disabled tri-state buffer.
Warning: The bidir "ADDR_IN[7]" has no source; inserted an always disabled tri-state buffer.
Warning: The bidir "ADDR_IN[8]" has no source; inserted an always disabled tri-state buffer.
Warning: The bidir "ADDR_IN[9]" has no source; inserted an always disabled tri-state buffer.
Warning: The bidir "ADDR_IN[10]" has no source; inserted an always disabled tri-state buffer.
Warning: Inserted an always-enabled tri-state buffer between logic and the tri-state bus DATA_IN[0]~7 that it feeds
Warning: Inserted an always-enabled tri-state buffer between logic and the tri-state bus DATA_IN[1]~6 that it feeds
Warning: Inserted an always-enabled tri-state buffer between logic and the tri-state bus DATA_IN[2]~5 that it feeds
Warning: Inserted an always-enabled tri-state buffer between logic and the tri-state bus DATA_IN[3]~4 that it feeds
Warning: Inserted an always-enabled tri-state buffer between logic and the tri-state bus DATA_IN[4]~3 that it feeds
Warning: Inserted an always-enabled tri-state buffer between logic and the tri-state bus DATA_IN[5]~2 that it feeds
Warning: Inserted an always-enabled tri-state buffer between logic and the tri-state bus DATA_IN[6]~1 that it feeds
Warning: Inserted an always-enabled tri-state buffer between logic and the tri-state bus DATA_IN[7]~0 that it feeds
Warning: TRI or OPNDRN buffers permanently enabled
Warning: Node "DATA_IN[0]~16"
Warning: Node "DATA_IN[1]~17"
Warning: Node "DATA_IN[2]~18"
Warning: Node "DATA_IN[3]~19"
Warning: Node "DATA_IN[4]~20"
Warning: Node "DATA_IN[5]~21"
Warning: Node "DATA_IN[6]~22"
Warning: Node "DATA_IN[7]~23"
And i have no idea what the warnings mean.
Could someone help me to figure it out?
Thanks!
You've defined the signals as INOUT but only used them as inputs so it has disabled the tri state buffer because it never ouputs a value.
Thanks for the valuable information.
Actually DATA_IN is bidirectional, i read from and write to it.
Yes, DATA_IN is a bi-directional signal but you don't get a "Signal has no source" warning about DATA_IN.
The warnings about DATA_IN simply say that the signal is never tri-stated so it's tri-state buffer is always enabled.
i see, Quartus much smarter than i :)
