21615 Discussions
Simple Delay in VHDL (sanity check)
Anyone availible to help me with a quick sanity check :) .
I created a simple delay in vhdl.
My testbech offers an input clock with 40ns period and 50% duty cycle so plently of time to allow the required transitions.
The problem is that when i run the simulation clk_out doesnt make any transitions at all.
This must be a simple mistake but i cannot see it.
library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; ENTITY clk_delay IS PORT ( clk_in : IN STD_LOGIC; clk_out : OUT STD_LOGIC); END clk_delay; ARCHITECTURE behav OF clk_delay IS BEGIN P1: PROCESS (clk_in) BEGIN IF clk_in'EVENT AND clk_in = '1' THEN clk_out <= clk_in AFTER 5ns; END IF; END PROCESS; END behav;
If anyone can help i will be forever grateful.
FYI: Quartus ii V8.0 with Quartus simulator.
Ade.
Quartus simulator doesnt support this kind of behavioural code because it simulates post synthesis netlists. You cannot synthesise delays.
The output you get will just be a registered version of your clock, which will always be the same value.
You will have to use modelsim to see this.
thanks for the quick response.
I have modelsim i will install and try it.
From the code i posted, do you agree that if clk_out were mapped to a pin and measured with a scope it would essentially by the same as clk_in with the 5ns delay (and obivously taking into account any timing issues in the fitting process).
regards.
--- Quote Start ---
regards.
--- Quote End ---
No
Delays cannot be compiled in quartus. You have to use a Phase lock loop and move the clk_out 45 degrees out of phase wrt clk_in.
>No
I would be even more specific.
Delays cannot be synthesized with VHDL or Verilog code.
You can simulate a delay.
You cannot generate a circuit with a given delay.
--- Quote Start ---
regards.
--- Quote End ---
No, even in simulation this would not be the case.
Because clk_out would always be '1' because there's only an assignment if clk_in = '1'.
So if you want a delayed clock, use an PLL (preferred, deterministic) or just use clk_out <= clk_in without the if....statement and depend on the path dalay (not preferred, not deterministic)
Success, Ton
