21611 Discussions
Simulate problem about (altfp_sqrt) core
:confused::confused:In my program I just implement an IP core(altfp_sqrt) by using megawizard. however after simulation by modelsim, the result always shows as high Z.
Can any body help to solve this problem? Thank you very much!!!
/*****************program********************************/
module sqrt (clk, idin, dout);
input [31:0] idin;
output [31:0] dout;
input clk;
wire [31:0] idin;
wire [31:0] dout;
ddr ddr_sqrt (
.clock(clk),
.data(idin),
.result(dout)
always @ (posedge clk)
$display ("dout = ", dout);
endmodule
/**************test bench************************************/
module sqrt_tb;
reg clk;
reg [31:0] data;
wire [31:0] idin; // data in
wire [31:0] dout; // data out
assign idin = data;
always# 10 clk = ~clk;
initial
begin
clk = 0;
data = 'b100;
end
sqrt m(clk, idin, dout);
endmodule
ddr ddr_sqrt ( .clock(clk), .data(idin), .result(dout) );Check that your MegaWizard generated altfp_sqrt module instance is indeed named "ddr".
thank you . but I checked the altfp_sqrt module name is right.
And I re-do the whole program, it still has the same problem.
/***************Top Module ****************/
module fp_sqrt (clk, idin, dout);
input clk;
input [31:0] idin;
output [31:0] dout;
wire [31:0] idin;
wire [31:0] dout;
sel_sq fp_sqrt_sq (
.clock(clk),
.data(idin),
.result(dout)
begin
$display ("idin= ", idin);
end
endmodule
/****************ALTFP_SQRT CORE********************/
// megafunction wizard: %ALTFP_SQRT%VBB%
// GENERATION: STANDARD
// VERSION: WM1.0
// MODULE: altfp_sqrt
// File Name: sel_sq.v
// Megafunction Name(s):
// altfp_sqrt
// Simulation Library Files(s):
// lpm
// THIS IS A WIZARD-GENERATED FILE. DO NOT EDIT THIS FILE!
// 10.1 Build 197 01/19/2011 SP 1 SJ Full Version
//Copyright (C) 1991-2011 Altera Corporation
//Your use of Altera Corporation's design tools, logic functions
//and other software and tools, and its AMPP partner logic
//functions, and any output files from any of the foregoing
//(including device programming or simulation files), and any
//associated documentation or information are expressly subject
//to the terms and conditions of the Altera Program License
//Subscription Agreement, Altera MegaCore Function License
//Agreement, or other applicable license agreement, including,
//without limitation, that your use is for the sole purpose of
//programming logic devices manufactured by Altera and sold by
//Altera or its authorized distributors. Please refer to the
//applicable agreement for further details.
module sel_sq (
clock,
data,
result)/* synthesis synthesis_clearbox = 1 */;
input clock;
input [31:0] data;
output [31:0] result;
endmodule
/**********************testbench*************************/
input clk;
input [31:0] idin;
output [31:0] dout;
wire [31:0] idin;
wire [31:0] dout;
sel_sq fp_sqrt_sq (
.clock(clk),
.data(idin),
.result(dout)
begin
end
endmodule
