21608 Discussions
Simulate with ModelSim SE6.5 error
Hi Dears:
I simulated rom with ModelSim 6.5 and got below error:
"# ** Error: (vsim-13) Recompile altera_mf.altsyncram because std.textio has changed.# ** Error: (vsim-12) Recompile work.ppucore(rtl) after altera_mf.altsyncram is recompiled.# Load interrupted# Error loading design"
Do anyone encounter these errors?
Below is my simulation tcl file comments:# Compile all source files and testbench
project compileall# Load design into simulator incorporating megafunction and transceiver# libraries
vsim -L lpm -L altera -L altera_mf -L sgate -L ArriaGX -L arriagx_hssi -t 1ps work.ppucore_tb# Set up Wave window with transceiver block signals
do wave.do
run 20 us
Attachment is the screen saved.
Dealed!
The new version can't simulate old project correctly, the issue is removed after rebuilding the ModelSim project.
