21615 Discussions
Simulink IIR Bandpass filter on DE2
I made a filter with matlab simulink and used one of its tools to create vhdl code out of it. I implemented it on an FPGA and it gives me reasonable output except that the frequencies that it pass are not the frequency I designed it to pass. When testing in matlab, a FFT of the output from the filter gives a single peak at 82Hz, but the filter on the board passes 56Hz as well at 170Hz. Any idea what would cause this? Thanks for the help.
The question doesn't seem particularly related to Altera FPGA or tools, but did you set the correct clock frequency when creating the filter?
I'm sorry to have been vague. I am implementing this filter on a Cyclone II DE2. I'm feeding data in from the audio codec. I'm using the ADCLRC clock. Would that be correct or incorrect?
ADCLRC seems reasoanable as a filter sampling clock. The results seem to indicate, that the actual clock frequency is different from calculated value.
The said 170 Hz looks like a 3rd harmonic, either caused by a distorted signal source, ADC overload or filter truncation errors (You didn't tell about relative amplitudes or the filter word length).
Would my vhdl code be at all useful? It was created automatically by Matlab Simulink. I attached the .vhd file. I hope that works.
I wonder, which filter specification is represented by the VHDL code. The coefficients look strange.
Alright, I'm sorry to dissapear and reappear with such a change in problem but...
I realized part of my problem is that I'm not converting the bitstream out of the codec into parallel quite correctly. Also, I can't quite seem to turn off bypass mode. In fact, I compiled and ran a project provided by altera and it lists that it's not in bypass mode, but it seems to still be bypassing. Does anyone have any insight on this?
I am including the project zipped up as an attachment.
