21598 Discussions
Single precision converter [Verilog]
Do you know if they is any verilog library or something for converting an integer to floating point [32 bits]. Thank you.
If the problem is dedicated to synthesis, look for floating point MegaFunctions.
Thank you for the reply.
Someone told me that using fixed point instead will require less resources. Do you know of any libraries for implementing math functions (such as exponential and division) for fixed point? With Verilog?
Thank you.
