Slow Slew Rate
GD76
How does the slow slew rate option works? In Quartus using MAX V CPLD 5ns part, in assignment editor if "SLOW SLEW RATE" is turned OFF and enabled is Yes, not timing violation. However, if turnd ON and enable is Yes or No, getting timing violation. With 4ns part, both gives no timing violation.
If "SLOW SLEW RATE" is turned OFF and enabled, shouldn't that give timing violation on slower 5ns part vs 4ns. Looks like the ON/OFF works the opposite.
RichardTanSY_Altera
Hi @GD76
May I know does my latest reply helps?
Do you need further help regarding to this case?
Richard Tan
p/s: If any answer from the community or Intel support are helpful, please feel free to give Kudos.
RichardTanSY_Altera
Hi @GD76
A slow slew rate reduces system noise, but adds a nominal output delay to rising and falling edges. The lower the voltage standard (for example, 1.8-V LVTTL) the larger the output delay when slow slew is enabled. Each I/O pin has an individual slew-rate control, allowing you to specify the slew rate on a pin-by-pin basis. The slew-rate control affects both the rising and falling edges. If no slew-rate control is specified, the Quartus software defaults to a fast slew rate.
For detailed functions, search for the keyword "Slew Rate" from the Device Handbook of each device and check.
Reference: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-v/max5_handbook.pdf
Richard Tan
RichardTanSY_Altera
Hi @GD76
Richard Tan
