Sof2flash
I'm trying to convert .sof file in .flash file for EPCS .
I'm using this command:
sof2flash --input=.... --output=.... --offset=0x.... --epcs
I have this question: if I try to change offset I can see the same .flash file as output.
Change just only first row.
I don't understand why. Somebody know how run epcs offset for sof2flash?
BYE
G
I'm afraid I don't have an answer for you but you're not the only one. I've just come across exactly the same problem trying to do the same thing! :(
Andy
edit to add -
I am using the following command:
sof2flash --epcs --input=hw.sof --output=hw.flash --offset=0x300000and I am using the 7.2 version (fully licensed) of the Quartus tools
Hi Andrew,
this question is a little bit strange. i don't understand why there are these problems. I didn't try but there are differences if I use WEB free quartus and NIOS II versions? versions.
With .flash I have to program epcs but not directly but with EPCS controller so my HOST MICRO, with SPI connection, program EPCS.
I have to know some important details.
Bye
G
Please look at step4 in the wiki.
http://nioswiki.com/guide_to_2c35_cf_with_u-boot
You may use u-boot/arch/nios2/cpu/epcs.c, or u-boot spi flash + stmicro + altera_spi.
http://nioswiki.com/dasuboot
- Hippo
