21611 Discussions
Some basic questions about DDR
Hi all,
I am studying the RTL based example code of LPDDR2 demonstration of Cyclone V 5CGXFC5C6 development kit from Terasic.
Basically, this demo code utilizes a LPDDR2 IP, and then write in-->read back all address to verify the whole memory, according to the statement of the user manual.
The LPDDR2 is a 16M x 32 x 8banks chip, with 32 DQ signals all connected to FPGA, as listed in the figure "lpddr2 circuit" in attachment;
The code has also been attached in case you are interested, with "(top level)c5g_lpddr2_rtl_test.v", and "(test part)avalon_bus_rw_test.v";
the diagram of the whole project is illustrated using the figure "project structure",
I also made a figure "signal connection" to illustarte the signal connections internal and external for the ease to understand, and save your time;
The settings of the LPDDR2 IP is listed in figure "ip setting_1","ip setting_2" and "ip setting_3";
I have spent several weeks on the code and reading a lot of datasheets, still with some confusions.
(1) The UNIPHY-Mem interface, DQ, is 32-bit, and in 'IP Setting_1', the Avalon-MM interface is set as "Full Rate", why generated IP data width of Avalon is still 32-bit?
output wire [31:0] avl_rdata_0, // .readdata
input wire [31:0] avl_wdata_0, // .writedata
They should be 64-bit, right? Since UNIPHY-Mem is 32 bit with DDR, AFI (only can be single data rate) with Full rate should be 64-bit. Right? What am I missing?
(2) In 'IP Setting_2', it sets the 'Mode Register 1--Burst length' to 8; here should be UNIPHY-Mem interface;
In 'IP Setting_3', it sets 'Maxium Avalon-MM Burst length' to 4; here should be external-controller interface;
In the code, it sets Avl_size to 1;
Literally, I understand what does 'Burst' mean; but here, does 'Mode Register 1--Burst length = 8' mean, any read/write between UNIPHY and memory, must be in 8-word(32bit/word) unit? And although Avalon burst is set to 4, but actually Avl_size has limited this Avalon burst length to only 1, right?
(3) Why the code uses afi_half_clk, not afi_clk, to read/write to/from the controller? This really confuses me. The Avalon interface is set as full-rate SDR with 32bit, but the code uses half rate clock still with 32bit to read/write, why? Why it doesn't use afi_clk?
My questions are pretty long, thanks so much for your time and patience, and really appreciate if you can give me any hint~~
IP Settings here
I just found that if I de-select the "Enable Hard External Memory Interface" in figure "IP Setting_1", then the data width of avl_rdata and avl_wdata will comply with the rule: Full rate -- x2; Half rate -- x4.
If I select this feature, then I can only select "Full rate", and data bus would be 32, the same with DQ width of memory chip.
So, what is going on here?
first... is this hdl compilation success?
