21600 Discussions
Some issue with "ASMI IP parallel ip"
open01
Hi ,
I am currently trying to use PCI-E to transfer data(8byte/once) and write the data to EPCQ through ASMI(page write), but unexpected phenomena appeared in the result, as shown in Fig.
Here is the data I transferred:
And when I use SignalTap to check the input waveform of "ASMI IP", the status is all good, as shown in Fig(The beginning data matches the data I transmitted, in order A1h, A2h, A3h, A4h, A5h, A6h, A7h, A8h):
But when I checked the data from EPCQ, I found that the data was wrong.
So why does SignalTap look good, but the result is wrong?
Does anyone have some ideas to share with me?
Thanks for your answers.
open01
Thanks for your response.
Finally I know where the problem is.....
Because when I use page write, I have to pay attention to the relevant regulations of start address as shown in user guide,
Thanks again for your assistance.
YuanLi_S_Intel
Can you try to remove the sector before writing into it? Also, you might need to have some delay after executing write operation.
Bruce
open01
