Hi! Has anyone successfully been able to output sound on their DE2i-150 board? The board's default program and one of the demonstrations that came with the CD are supposed to play audio, however they do not. The following are instructions from the board's manual pertaining to the default program. "Place slide switch SW17 in the DOWN position to hear a 1 kHz humming sound from the
audio-out port. Alternatively, if slide switch SW17 is in the UP position, and optionally connectsthe microphone in port with a microphone and/or connects the line-in port with an audio player'soutput, you will hear the sound from the microphone or audio player or mixed sound from both. " My board was not outputting such a sound. In addition I tried the TV demonstration code which also did not output sound as it was supposed to. Lastly, I used the built in Linux distro and tried to play an MP3 from my flash drive but this failed. I've tried this on two DE2i-150's and they both did not work. If someone has gotten sound to work on one of them can you please let me know how. Thanks!- Tags:
- Verilog
