Sram
Dear all;
i need to know how to use information stocked in my SRAM with VHDL instruction. let me explain more. i mean i have a file put on SRAM and i want to use value included into that file.i m writing a vhdl code and i don't know what instruction should i use to call the SRAM..thank you all.
Check the manuals. What is the typenumber of the SRAM? Put it into your favorite internet search engine and most likely you'll find the manual you need. I know it might be a lot of texts and diagrams, but it helps understand what it is you need to do.
well thank you ; i just need the syntax used in vhdl to call the sram. and what you mean by type number ??
You cant "call" SRAM from VHDL. SRAM is an external chip to the FPGA - so you need to write a controller to follow the timing specs of the external chip.
any exemple of controller or guide or help with it please
Or are you trying to create an internal SRAM?
