21611 Discussions
State Machine- State doesn't set logic as expected
The folowing code is designed to convert a 24 bit value in to 4x 6 bit values to transmit over a 6 conductor cable. At each state I define what my output clock should be by assinging a logic level to GeneratedClk. For some reason the output I get doesn't match what I expect. The clock only makes one cycle low and then back to high. I am sure there must be some easy explanation of how I don't understand variables vs. signals or something, but I would appreciate some advice.
entity DataTransmitter is
port (
ClkEnablePort : buffer std_logic;
DataRateClk : in std_logic;
SendData : in std_logic;
DataOutClk : out std_logic;
BusIn : in std_logic_vector(23 downto 0);
BusOut : buffer std_logic_vector(5 downto 0);
SendComplete : buffer std_logic;
Reset : in std_logic
end DataTransmitter;
architecture behavior of DataTransmitter is
type state is ( WaitingForData, Triggered,
SendBits0, LatchBits0, SendBits1, LatchBits1,
SendBits2, LatchBits2, SendBits3, LatchBits3,
SendFinish );
signal pr_state, nx_state : state;
signal GeneratedClk : std_logic;
signal Hold0 : std_logic_vector(5 downto 0); --Least Significant Bits
signal Hold1 : std_logic_vector(5 downto 0);
signal Hold2 : std_logic_vector(5 downto 0);
signal Hold3 : std_logic_vector(5 downto 0);
begin
---------- Advance States ----------
process( Reset, SendData, DataRateClk )
begin
if( Reset = '1') then
pr_state <= WaitingForData;
elsif ( SendData = '1' and pr_state = WaitingForData ) then
pr_state <= Triggered;
Hold0 <= BusIn(5 downto 0);
Hold1 <= BusIn(11 downto 6);
Hold2 <= BusIn(17 downto 12);
Hold3 <= BusIn(23 downto 18);
elsif ( rising_edge(DataRateClk) ) then
pr_state <= nx_state;
end if;
end process;
---------- Create Results for State Change ----------
process( pr_state )
variable SendThisData : std_logic_vector(5 downto 0);
variable GeneratedClk : std_logic;
begin
case pr_state is
when WaitingForData =>
nx_state <= WaitingForData;
GeneratedClk := '1';
SendComplete <= '0';
SendThisData := "000000";
when Triggered =>
nx_state <= SendBits0;
when SendBits0 =>
nx_state <= LatchBits0;
GeneratedClk := '0';
SendThisData := Hold0;
when LatchBits0 =>
nx_state <= SendBits1;
when SendBits1 =>
nx_state <= LatchBits1;
SendThisData := Hold1;
when LatchBits1 =>
nx_state <= SendBits2;
when SendBits2 =>
nx_state <= LatchBits2;
SendThisData := Hold2;
when LatchBits2 =>
nx_state <= SendBits3;
when SendBits3 =>
nx_state <= LatchBits3;
SendThisData := Hold3;
when LatchBits3 =>
nx_state <= SendFinish;
when SendFinish =>
SendComplete <= '1';
when others =>
end case;
DataOutClk <= GeneratedClk;
BusOut <= SendThisData;
end process;
Do not use buffer(obsolete).Your state transition is tied up to elsif...
If you just want to serialise 24 bits into time muxed 6 bits then there might be easier ways of doing what you want e.g.
signal count: integer range 0 to 3; process(reset,clk) begin if reset = '1' then count <= 0; input_en <= '0'; BusOut <= (others => '0'); elsif rising_edge(clk) then count <= count + 1; case count is when 0 => BusOut <= BusIn(17 downto 12); input_en <= '1'; when 1 => BusOut<= BusIn(23 downto 18); input_en <= '0'; when 2 => BusOut <= BusIn(5 downto 0); input_en <= '0'; when 3 => BusOut <= BusIn(11 downto 6); input_en <= '0'; end case; end process;
the input_en pulse is to control the input rate(= input clk/4). It needs some care to synchronise the data request to the front module. I have assumed the request is raised at count 0, becomes high at count 1 and data is available soon at count 2. Such design is called pull data flow(not push)
a good question
Thanks for the tips.
The state machine I had created was designed to latch-out the data on the SendBit(0-3) states and then send a rising edge (DataOutClk) on the LatchBits(0-3) states for the receiver to use to latch the data into the receiver. Unfortunately for some reason the DataOutClk doesn't toggle at every state as I would expect. It seems to skip the middle states. I believe that it enters the states but just doesn't toggle the DataOutClk by setting the GeneratedClk each time.
