Programmable Devices
21618 Discussions
Stratix® 10 GX DDR4 Memory calibration failed
Amay
In Apr, we requested the failure analysis of the DDR4 Memory calibration for 5pcs 1SG280HN2F43E2VG rejected samples.
Per Intel instruction we returned 3pcs samples of 1SG280HN2F43E2VG to Intel Lab for analysis in Aug.
Final report showed 2pcs Test Escapee of DDR calibration test and 1pcs NDF. Details refer to report CI2427-9514.
Now we still have 9pcs rejected samples with same failure, pls. release RMA for 9pcs samples or perform failure analysis again, thanks!
All unites have moved from PCBA because the PCBA need to return customer for function test again, pls. note it and thanks!
Farabi
I am Farabi and will process your RMA request. Do you have DPR(Device Problem Report) form for me to process the RMA?
regards,
Farabi
Amay
Hello Farabi:
Body mark photos for your reference, thanks!
Amay
Hello Farabi:
Have any update for 9pcs RMA request? it has pended some days, could you please support to update it? Thanks!
Amay
Hello Farabi:
I have attached the DPR report for your reference, thanks!
Farabi
Do you have access to file IPS (Intel Premier Support). I tried to process your RMA but they required to have IPS number. I can't proceed this RMA using forum case.
regards,
Farabi
Farabi
Hello, I would suggest you to contact your distributor and file IPS to proceed for RMA.
regards,
Farabi
