21607 Discussions
Stratix III: Problem with Row I/O CLK2p ... output
Dear all
I'm trying to output a clock on the combined "Row I/O, CLK2p, DIFFIO_RX_L15p, DIFFOUT_L29p" pad "U28" on my Stratix III EP3SL70 device.
Although Quartus notes no problem, the pad never drives the output. The fitter reporting shows a direct output path, so this should be fine.
Is there any additional assignment I have to set or are there limitations in the use of such combined pins? Or is it a problem putting an "internal" clock to a combined output pad with (in this application unused) clock input functionality? Putting the signal on a different pin works fine, however, this doesn't help in my application...
Anyone had similar issues? Any hint is very welcome!
Peter
The standard pin function is (single ended) IO, so it's supposed to work. I see two possible explanations:
- The pin isn't connected in your hardware
- A pin specific Quartus bug
First the pin connection should be checked, e.g. by using the pin as input.
Already tried this, and I was not able to read the input (and the signal was reportedly there on the net...). Actually, the behaviour is the same on several boards, and a test with external pull-up / pull-down resistors showed different behaviour with the pin used as FPGA input and output, so I don't expect any soldering or conectivity problems on my boards...
Problem solved!
I found out that the signed-off documents (schematic/layout) do not match with what the board suppliert delivered (by measuring on an unassembled board i got recently). The pin in question was simply not connected.
Thanks anyway for the help trials... ;-)
