21611 Discussions
Stratix III: Pull up resistor at open drain output to voltage higher than VccIO
Havana
I need to generate some slow 3.3V output signals at the GPIOs of my Stratix III on a bank which uses 2.5V VCC_IO. I have to use this voltage because I need LVDS inputs/outputs von these banks. And unfortunately, I have no chance to place these signals on an other bank.
Is it possible/allowed to use a pull-up resistor to 3.3V if my output is configured as open drain? I haven’t found any information about the maximum voltage at an open drain output.
The recommended Operating Condition says DC Input Voltage V_I(max) = 3.6V (1-4). For “2.5-V LVTTL/ LVCMOS”-inputs I found V_IH(Max) = 3.6V (1-9).
The Table 7-7 on Chapter 7 p19 allows 3.3V input voltages if the PCI clamp diode is activated. But I don’t want to limit my output voltage to 2.5V+V_diode.
Thanks for any advice.
SreekumarR_G_Intel
Is it possible/allowed to use a pull-up resistor to 3.3V if my output is configured as open drain?  Yes , But make sure the R Choosen correct so that current is limited .
I dont understand why you want compare the input specification for output buffer above VCCIO ?
Thank you ,
Sree
