21611 Discussions
Stratix V Hard IP for PCI Express (Root-point)
Dear Sir,
I am developing a product that uses the Altera FPGA (Stratix-V).
I am designing FPGA logic using Hard IP for PCI Express.
I assign the two PCI Express port in FPGA.
One port is assigned Native Endpoint, and other one port is assigned Root-point.
I have experience with the Endpoint, but I don't have experience with the Root-point.
So, I have some question.
1.On page 8-48 of "Stratix V Hard IP for PCI Express User Guide(May 2013)" have the following description.
"In Root Port mode, do not access the Configuration Space using TLPs and the LMI bus simultaneously."
Can I do? Configuration how without using the LMI?
2.Please tell me an example of setting the configuration space at the root-point.
3.When I use the Root-point on Hard IP, do I need any special settings compared to Native Endpoint?
Could you advice to me from these situations?
kahaluu
