21613 Discussions
Stratix V with Intel QPI 1.1 interface
Hi Forum
I would like to inquire about the article I read about interfacing stratixv fpga with intel qpi protocol interface (xeon processor)
QPI (Quick Path Interconnect)
http://newsroom.altera.com/press-releases/nr-qpi-home-agent-fpga-altera.htm
I am interested in purchasing the Stratix V FPGA which connects together with an Intel Xeon processor. (A bundle set if possible)
I would like to have more information about this especially on the both system interconnect.
How does the Intel Xeon processor connects to the Stratix V device.
Does it have a external physical interface ?
Thank you :)
Jeevan Sirkunan
Researcher
Fac. of Electrical Eng
Universiti Teknologi Malaysia,UTM Skudai, 81310 Johor,Malaysia.
Hello jeevan2,
From a quick glance on the article, it looks like by using the transcievers it's able to meet the Xeon processors requirements. I'm assuming this is a custom board with fpga and Xeon very close to each other. The protocol is an ip so it doesn't look to bad to use if they have a kit. It first would use the transceiver ip core to stabilize th connection and use the qpi ip core for comm.
-Trukng
-Trukng
