Programmable Devices
公告
21615 讨论
Stratix10 Global Clock assignment is ignored
mappy5
初学者
1,099 次查看
I'm trying to synthesize an IP using virtual pins.
The Clock signal of the virtual pin is directly connected to the IP.
Global Signal ON is set in the assignment editor for the clock of the virtual pin.
However, when I check the list of Use clock options in the Timing Optimization Advisor, the Global Resource Used for the clock signal is No.
There is no Global Clock synthetic Warning or Warning for Clock signals in the log.
When I tried it with Arria10 in the same way, I was able to assign it to the Global Clock in Arria10.
How can I assign a Clock to a Global Clock in Stratix 10?
  • Quartus Version : Pro 20.3.0 Build 158
0 项奖励
4 回复数
SyafieqS
员工
1,091 次查看
Global Signal assignments only controls whether a signal is promoted using the specified dedicated resources or not, but does not control which or how many resources are used.
To take full advantage of the routing resources in a design, make sure that the sources of clock signals (input clock pins or internally-generated clocks) drive only the clock input ports of registers
0 项奖励
mappy5
初学者
1,087 次查看
Hi SyafieqS_intel,
Will assigning a virtual pin to a dedicated CLK pin solve the problem?
Is the GCLK allocation method different between Stratix10 and Arria10 due to the difference in clock resources?
0 项奖励
SyafieqS
员工
1,068 次查看
Yes, Stratix 10 and Arria 10 have different architecture and clock network.
0 项奖励
SyafieqS
员工
1,037 次查看
May I know if there is any update?
0 项奖励
回复
