Stratix5 PLL
I had generated Stratix5 PLL (s5_pll) using Megawizard Plugin and the created pll instance is pll_test_0002 with a top level wrapper arouND IT.
tHE GENERATED FILE IS SHOWN BELOW;
module pll_test ( input wire refclk, // refclk.clk input wire rst, // reset.reset output wire locked, // locked.export output wire outclk_0, // outclk0.clk output wire outclk_1 // outclk1.clk ); pll_test_0002 pll_test_inst ( .refclk (refclk), // refclk.clk .rst (rst), // reset.reset .locked (locked), // locked.export .outclk_0 (outclk_0), // outclk0.clk .outclk_1 (outclk_1) // outclk1.clk ); endmodule
Now i have a top level instance top.v with instance pll_test along with some sub-modules.
While synthesis in Quartus, toll gives below error;
Error (12006): Node instance "s5_pll_inst" instantiates undefined entity "s5_pll_0002"
Error: Quartus II 32-bit Analysis & Synthesis was unsuccessful. 1 error, 0 warnings
This error indicates, s5_pll_0002 (generated by Megawizard), Quartus tool is not able to identify.
Please guide me to get rid of this error.
freak
what release are you using? i recommend the latest when targeting SV
that said i have successfully compiled SV designs that include PLLs
This is a VERILOG code. I am using 11.2 Quartus release.
Please guide.
freak
Do you see the qip file in the design files.?
there should be a pointer to the sub files in the mega-function directory that will include the pll_test_0002 file
Hi connollytr,
Thanks for your input. You were little late :)
I got this file few days before and things are working...
Thanks u all !!
Jaseel
