Programmable Devices
21409 Discussions
TSE_MAC writing extra bits
Hello i am mounting some UDP packages inside NIOS2 and sending them via ETH0, however i am getting some malformed packages errors when i take a look at them with Wireshark.
I tried to increase the data and instruction cache to 16/32K but no improvements happened. I am using altera TSE mac at a DE2-115,
When my eth interface sends the packet it always try to complete 32 bits
For exemple
0A 0B 0C 0D
0E 0F
is a valid package
but eth0 is writing
0A 0B 0C 0D
0E 0F 00 00
Any suggestions?
The MAC has an option to align data to 32bit boundary, so add 16 bits of any data in the begining of the data OR disable that option.
Ok but why the ping doesnt align the data?
When i ping with my DE2-115 everything is ok at the wireshark and it isnt aligned.
I also disabled the option to align at the MAC but nothing changed.
Strange, it had to change the alignment. The alignment is probably can be done in TCP/IP stack. Check that too.
