21616 Discussions
TUV Rheinland certification 968/EL 850.01/19
MY55
Hello, we are in a process of developing functional safety solution based on Cyclone 10.
We got the certificate 968/EL 850.00/12. However, we were told by our certifiying body, TUV Rheinland, that the current valid certificate is 968/EL 850.01/19 and the othes are not valid.
Where can we get the certificate 968/EL 850.01/19 ?
NurAiman_M_Intel
Thank you for contacting Intel community.
For Functional safety related, please contact your local Intel sales representative for more information.
https://www.intel.com/content/www/us/en/industrial-automation/programmable/applications/automation/functional-safety.html
Aiman
MY55
Thank you.
I have contact already local representative and what I got from him is certificate 968/EL 850.00/12 which is listed also in the link that you have provided. However, as mentioned in the previous thread, we were told by our certifying body, TUV Rheinland, that the current valid certificate is 968/EL 850.01/19 and the others are not valid. That means 968/EL 850.00/12 is not valid. What we basically need is the Quartus version and the list of FPGA's that are qualified per 968/EL 850.01/19 as well as the 968_EL_850_01_19_RL_2019_08_23.pdf that list the certified functions. This info is critical for our safety project. We need Intel’s help to get this info.
MY55
Dear Aiman,
NurAiman_M_Intel
I am checking this with our internal team. I will get back to you once I received the answer.
Thank you.
Aiman
NurAiman_M_Intel
Please clarify which release of Quartus the are you using and which version of the FSDP (Functional Safety data pack)?
Aiman
MY55
Hi Aiman,
I am not usign any FSDP. What we  need is the Quartus version and the list of FPGA's that are qualified per 968/EL 850.01/19 as well as the 968_EL_850_01_19_RL_2019_08_23.pdf that list the certified functions.
Is it possible to download the ceritifed Quartus version per  968/EL 850.01/19 ?
Is it possible to download the file 968_EL_850_01_19_RL_2019_08_23.pdf ?
NurAiman_M_Intel
May I know where did you downloaded the certificate as that is only supposed to be available with the FSDP?
Information from our FuSa team,
The certificate is only available as part of the FSDP, and the FSDP needs to be purchased by the customer and under NDA. For Cyclone 10 LP support the customer will need to order FSDP version 5 which supports Quartus Prime Standard 17.0.2.
Hope this clarify.
Aiman
MY55
It tooks a while to get info from our local.
The P/N for FSDP version 5 that I got is: IP-ABG-SAFETYDP5. However the pdf associated with this P/N :
https://www.intel.com/content/dam/www/public/us/en/documents/solution-briefs/functional-safety-solution-brief.pdf
does not include the Cyclone 10 LP as mentioned above.
What version of FSDP includes the Cyclone 10 LP ?
Can I get the P/N and the 'SOLUTION BRIEF' (pdf) of this version ?
Thank you
NurAiman_M_Intel
We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
