21615 Discussions
Tcl script to invoke time quest
I had a simple question, what is the command to invoke time quest in the TCL script? i need this result urgent.
Any help would be very much appreciated.
thanks
Best regards
ken
qexec "quartus_sta <project_name>"
Thanks for your prompt replying,
I had tried to use the command and it works well. I am trying to used quartus_sta myproject -c myproject_hcii base on the TCLReference Manual but failed.
I am trying to save the result in one of the file? how do I do it?
BTW, is that possible for us to invoke this command once the compilation finish? If can what I need to do to include the command above?
currently I run the TCL script by tools -> tcl scripts -> run
Is that possible to call the Timequest menu out and right click on the slack failure and report timing after the simulation done?
I am sorry; I am quite new in this TCL script. Kindly assist.
this should help with automatically running your scripts:
http://www.altera.com/support/examples/tcl/auto_processing.html
you can redirect output to a file:
qexec "quartus_sta <project_name> > <log_name>.txt"
Thanks for your great help!
I am very new to tcl script and I saw a post regarding this. So I tried to used "POST_FLOW_SCRIPT_FILE" but I am not sure when it is executed.
I want to execute the same tcl script AFTER the time_quest sta finished at once.
Is "POST_FLOW_SCRIPT_FILE" appropriate to realize the operation above ?
I don't want to execute the scripts before timequest sta.
Thanks for any help in advance.
Best regards
Angel
