21615 Discussions
Terasic Multi-Touch LCD Help
Hey guys,
I am working on a student project that uses the DE2-70 and the Terasic multi-touch LCD module. I am coding in Verilog on Quartus and am designing a touchscreen music synthesizer. Terasic provides an IP touch controller that is used to read in touches, gestures, and locations. Unfortunately, I have not been able to get a touch response from the unit. Nor have I been able to figure out how to output to the LCD screen. I also haven't been able to get Terasic's 2 demos up and running. I would greatly appreciate any help in setting the MTL module up or reference to additional documentation.
Terasic's IP touch controller that has the following inputs and outputs:
iCLK: Input- Connect to 50MHz Clock
iRSTN: Input- Connect to system reset signal
iTRIG: Input- Connect to Interrupt Pin of Touch IC
oREADY: Output- Rising Trigger when following six output data is valid
oREG_X1: Output- 10-bits X coordinate of first touch point
oREG_Y: Output- 9-bits Y coordinate of first touch point
oREG_X2: Output- 10-bits X coordinate of second touch point
oREG_Y2: Output- 9-bits Y coordinate of second touch point
oREG_TOUCH_COUNT: Output- 2-bits touch count. Valid value is 0, 1, or 2.
oREG_GESTURE: Output- 8-bits gesture ID (See Table 3-4)
I2C_SCLK: Output- Connect to I2C Clock Pin of Touch IC
I2C_SDAT: Inout- Connect to I2C Data Pin of Touch IC
According to the manual, iTRIG, I2C_SCLK, and IC2_SDAT pins should be connected to the MTL_TOUCH_INT_n, MTL_TOUCH_I2C_SCL, and MTL_TOUCH_I2C_DAT signals in the 2x20 GPIO header respectively. When oREADY rises, it means there is touch activity, and associated information is given in the oREG_X1, oREG_Y1, oREG_X2, oREG_Y2, oREG_TOUCH_COUNT, and oREG_GESTURE pins.
They also give the mapping for the GPIO ports on the DE2 which I converted to GPIO ports of the DE2-70.
Note* I also have access to the Altera DE2 board, but would prefer to use the DE2-70
Thanks!
*Update*
I received an email back from Terasic's tech support team. Unfortunately, they did not provide any help. They suggested looking over the demo code and trying out the demos. As I said earlier, I have tried to use the demos but they do not currently work. I'm really at a lose for how to proceed forward with my project. Any help would be greatly appreciated.
Thanks!
Hi Flartiz,
I'll have our support team give you more guidance on the subject and give you a direct demonstration for the DE2-70.
Thanks ayhoung!
I am now receiving touch inputs correctly on the DE2 board. It turns out that iTRIG has negative polarity. It means a lot to know that you and your support team actively read the forums and help customers. =) I look forward to learning from your direct demonstration and would still appreciate any help with drawing shapes on the LCD screen.
Thanks!
flaritz, did you figure out how to draw shapes on the LCD module. I am using the same module for my project on a DE2 board. Did you find any useful resources for using the module?
