21607 Discussions
There is an error in selecting GXT channel
lance9
In the L-Tile/H-Tile Transcever Native PHY Intel Stratix 10FPGA IP , set the VCCR_GXB and VCCT_GXB  supply voltage for the transceiver to 1_1V, select GXT for transceiver channel type ,select Basic(Enhanced PCS) for Transceiver configuration rules, and set Data rate to 16000M. Use the default parameters for the rest of the settings. There will be an error as shown in the figure below:image.png
Kshitij_Intel
Please refer the Specs.
2.3.2. GXT Channels (intel.com)
It seems your data rate is out of range for GXT Channels.
Thank you,
Kshitij Goel
lance9
Thank you for your reply.
If I set Data rate to 18000Mbs I will get the following error:
Kshitij_Intel
Please check and set all your parameters as per specifications.
Also, use the latest IP with latest Quartus version.
If still issue exist, please share your project QAR.
Thank you,
Kshitij Goel
Kshitij_Intel
As we do not receive any response from you on the previous answer that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Thank you,
Kshitij Goel
