Dear all,
I Have problem in Quartus where I want to read the Fmax in TimeQuest Timing Analyzer after compilation. But, I cant find the folder report for Slow 1100mV 85C Model under the TimeQuest Analyzer section. Can anyone help me..I use Stratix III family. ThanksLink Copied
Go into your project settings and check the operating settings and conditions. There you can set up voltages and temperatures, and Timequest will use them in its report.
How come I did not do any of these settings and I was still able to get the folder "Slow 1200mV 85C Model">
Thanks.- Mark as New
Quartus uses default settings for the operating conditions, depending on the device you selected.
Thanks you
Hello Daixiwen,
What exactly are wildcards? Thanks, AA- Mark as New
I'm not sure I understand what you are asking, or in what context... Wildcard characters are special characters that can define a search pattern. Characters such as ? or * are commonly used.
I'm sorry! I had wildcard IO pins in my mind when I asked that question
