21615 Discussions
Track signal in Verilog testbench for limited time
Hi everybody,
And TGIF !! (Thank goodness its friday, I see a beer in my future !!).
A Verilog question; I want to track a signal at every clock edge
in my testbench, but only when I activate a "switch" variable.
Such as:
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} st1\:*{behavior:url(#default#ieooui) } #100 activate_signal_tracking = 1'b1;
test_status = signal_to_track;
#100 activate_signal_tracking = 1'b0;
So I want test_status to get the value of signal_to_track at every clock edge, but only while the activate_signal_tracking is set.
It would be good be able to track different signals also.
Not quite to simple I have found after trying various ideas, seems like I need a verilog task which I turn on and off somehow ?
The monitor statement will print changes of the variable to the screen,
but I want to track the test status.
Thanks a bunch for the help, whoever gives the right answer and is close to Freiburg Germany gets a beer from me tonight, lol !! :)
Have a good weekend !
Eric
Use always block with if conditions. Such as:
always @(posedge clk) begin : track_it if (activate_signal_tracking) begin : active_track test_status = <my_path>.signal_to_track; // .. more such signals to track if needed end : active_track end : track_it
If you use SystemVerilog you can also use the iff gating as in:
always @(posedge clk iff activate_signal_tracking) begin : track_it test_status = <my_path>.signal_to_track; // .. more such signals to track if needed end : track_it
HTH
Srini
www.cvcblr.com/blog
Hello Srini,
Just got back from vacation, thus the late reply.
Thats pretty much how I wrote the testbench code,
thanks a bunch !!
Cheers,
Eric
