- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
i have some problems with test about transceiver on Arria10 GX. My goal is: check transceiver comunication with different speed. I have already done a test a 5Gbps with Native PHY with indipendent Tx and RX block with Standard PCS (10bit) and Bitslip. The test was successful. Now i want to test the comunication at 10Gbps using Enhanced PCS (64bit) and Bitslip. The parallel receved are wrong, but the bitslip shift the word by 1 bit every rising edge. The receved word is wrong, because have more '1' than i send by TX. it seems that an internal coding is applied to the block, but every block aren't enabled. My option are: PCS-PMA interface 64 FPGA fabric interface 64 RX FIFO mode phase compensation FIFO partially full threshold :23 FIFO partially empty threshold: 2 Enable Rx data bitslip Eenable rx_bitslip port TX: FIFO mode phase compensation FIFO partially full threshold:11 FIFO partially empty threshold:2 Any advice? Thanks, Marco- Etiquetas:
- transceiver
Enlace copiado
0 Respuestas
Responder
Opciones de temas
- Marcar tema como nuevo
- Marcar tema como leído
- Favorito
- Suscribir
