21611 Discussions
Transceiver toolkit & Nios2 conflict
I have a design in which I instantiated a Nios subsystem and a transceiver toolkit example (http://www.altera.com/support/examples/download/transceiver_toolkit_13_0sp1_qar.zip) (with number of lanes adjusted to my particular design). So my top module instantiates two qsys designs.
The problem I encounter is that Transceiver Toolkit cannot detect the transceivers! the design works however if i remove the nios from the build (not an option for my work).
This looks like an Altera issue - but unfortunately I found no other references in the Altera Knowledge center or this forum. Has anyone else encountered this problem? I'd appreciate any hints...
Thank you!
Platform: Stratix V GX Development Kit.
The problem was solved in Quartus 13.1.
I believe it was a synthesis problem, because the bitstream generated with 13.1 now works with the GUI of 13.0sp1 as well.
