21592 Discussions
Trouble with Cyclone IV FIFO
Hello, i use modelsim6.5, i have design with two type of fifos. If i try use simulation there is this error:
# ** Fatal: (vsim-3420) Array lengths do not match. Left is 8 (7 downto 0). Right is 32 (31 downto 0).# Time: 0 ns Iteration: 0 Process: /tb_toplevel/top_testbench/merici_frontend/gen_fifos__1/fifos/line__47318 File: C:/modeltech_6.5b/win32/../altera/vhdl/src/altera_mf/altera_mf.vhd# Fatal error in Architecture behavior at C:/modeltech_6.5b/win32/../altera/vhdl/src/altera_mf/altera_mf.vhd line 47320
Declaration of fifo is:
dcfifo_mixed_widths generic map ( intended_device_family => "Cyclone IV E",
lpm_hint => "MAXIMIZE_SPEED=5,",
lpm_numwords => 256,
lpm_showahead => "OFF",
lpm_type => "dcfifo",
lpm_width => 32,
lpm_widthu => 8,
lpm_widthu_r => 10,
lpm_width_r => DATA_WIDTH,
overflow_checking => "ON",
rdsync_delaypipe => 3,
underflow_checking => "ON",
use_eab => "ON",
write_aclr_synch => "ON",
wrsync_delaypipe => 3)
port map ( rdfull => rd_fifo_full(i),
wrclk => CLK,
rdempty => rd_fifo_empty(i),
rdreq => fifo_rd_en(i),
aclr => reset,
wrfull => wr_fifo_full(i),
wrempty => wr_fifo_empty(i),
rdclk => CLK,
q => fifo_output(i),
wrreq => pulse_from_sensor(i),
data => cnt_to_fifo(i));
width is 32b for cnt_to_fifo and 8b for fifo_output. I dont know waht is wrong, because width is the same.
If i try use it in the Cyclone II (i change device type) simulation is working with these settings.
Any suggestions?
Thank you, Vaclav
