21611 Discussions
Trying to Identify this ALTERA based motion control card manufactuer
Anybody know who made this card ISA interface
I have not been able to find much of anything on my motion control card.
I can tell you that it is an ISA 16 bit bus it is a full size card and it has 3 axis encoder inputs and 3 axis drive outputs (4 pin outs only 2 are used in my application)
The controller chip is made by ALTERA it is designated as FLEX numbers on the chip are EPF8282ALC84-3 & CDA239943
There is a white sticker with SE 362 B1 on it .
There is a 50 pin connector sticking thru the mounting bracket, 2ea 40 pin connectors (white), 4 black connectors on the back that are not being used.
Manufacturer discovered !!!!!!
CNC-Systems in France for Sharnoa
