Greetings.
As the UART module is connected to the HPS side of the FPGA. Is there anyway to access the UART peripheral from the FPGA side using verilog language without the use of NIOS II. (More precisely, can i write my own verilog module to transmit some bytes to the PC via UART interface?)
Any assistance in this regard will be highly appreciated.
Thank you in advance.
連結已複製
the question can be answered in two regards.
1. Can you implement UART function in HDL? Yes, there are many code examples on the internet.
2. Can the FPGA UART use dedicated HPS UART pins? Not in Cyclone V SoC. In so far FT232 on DE1 SoC board can only connect to HPS UART.
Hi mwac__,
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Aik Eu
