21602 Discussions
UPD receiving error while sending ok
I have used two ways to receive upd:
case 1: I used "DE2_UDP example" from http://www.btxsistemas.com.ar/net2.zip to send upd to PC,it's ok.But the received upd from PC always were not right.
Wireshark displayed as:
Source:Twinhead
Destination:Broadvast
Protocol:upd
Info:Whi has 192.168.253.8?
0000 ff ff ff ff ff ff 00 40 45 00 6e 69 08 06 00 01 .......@ E.ni....
0010 08 00 06 04 00 01 00 40 45 00 6e 69 c0 a8 fd 04 .......@ E.ni....
0020 00 00 00 00 00 00 c0 a8 fd 08
The message on the console from the board was:
Receive Packet Length = 64
FF,FF,FF,FF,FF,FF, 0,40,45, 0,6E,69, 8, 6, 0, 1,
8, 0, 6, 4, 0, 1, 0,40,45, 0,6E,69,C0,A8,FD, 4,
0, 0, 0, 0, 0, 0,C0,A8,FD, 8,FF,FF,FF,FF,FF,FF,
case 2: I used SimpleSocketServer to send upd to the board from PC,Wireshark displayed as:
Source:192.168.253.4
Destination:192.168.253.8
Protocol:upd
Info:Source port: 1024,Destination port: 1024
0000 01 60 6e 11 02 0f 00 40 45 00 6e 69 08 00 45 00 .`n....@ E.ni..E.
0010 00 32 00 24 00 00 40 11 ff 38 c0 a8 fd 04 c0 a8 .2.$..@. .8......
0020 fd 08 04 00 04 00 00 1e 48 2d 31 39 32 2e 31 36 ........ H-192.16
0030 38 2e 32 35 33 2e 38 32 30 31 30 30 39 32 30 31 8.253.82 01009201
The content"192.168.253.8201009201" above was exactly the data I send to the board.
It seems that in case 1 I have to declare that the IP of the board is 192.168.253.8.first.If it does,then how to declare the IP address.Since I does not like to use UCOSII in my system,so I have to solve the receive problem in case 1.
Looking for help.
Thanks in advance.
