Programmable Devices
21615 Discussions
USB blaster ii
What is the difference between USB blaster and USB blaster ii? Which hardware IC used extra in USB blaster ii which was not used in USB blaster?
One difference between the USB Blaster and USB Blaster II is the TCK frequency.
For USB Blaster the TCK is fixed which is around 6Mhz. However for USB Blaster II, user can change the TCK up to 24Mhz.
Also, the chip is different in the USB Blaster and USB Blaster II. You can refer to the USB Blaster and USB Blaster II user guide for the info.
https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug_usb_blstr.pdf
https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug_usb_blstr_ii_cable.pdf
Did usb blaster ii having external platform flash?
Which chip is different in USB blaster and USB blaster ii?
usb blaster II is using max device
and..... blaster II significantly having faster data transfer for supporting USB 2.0..
