21615 Discussions
Unable to select specific active serial configuration device in Quartus Pro "Device and Pin Options"
Steve-Mowbray-ENL
New Contributor II
Arria 10 and Quartus Pro 20.4
In Quartus Standard device and pin options we can select from a list of compatible flash devices however in Quartus Pro the "Configuration Device Options..." button is greyed out:
Capture.PNGHow do I tell Quartus Pro what configuration device to use for active serial configuration scheme in our project?
Steve
FvM
there's no need or purpose of setting a specific configuration device in Device Options, the device has to be set in Programming File Generator tool in case you are using indirect JTAG programming method for the flash.
Steve-Mowbray-ENL
New Contributor II
Thanks FvM -- this makes good sense but now I'm confused as to why Quartus Standard allows a configuration device to be selected in the equivalent Device and Pin Options section when using Standard edition -- perhaps it is an unused setting left over from previous versions...
NurAiman_M_Intel
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
