21613 Discussions
Unable to use EPCS device_Leaving target processor paused
#!/bin/sh# # This file was automatically generated by the Nios II IDE Flash Programmer.# # It will be overwritten when the flash programmer options change.#
cd C:/altera/91/quartus/work/firefight/software/code/Release# Creating .flash file for the FPGA configuration
"$SOPC_KIT_NIOS2/bin/sof2flash" --epcs --input="$QUARTUS_ROOTDIR/work/firefight/
firefighter.sof" --output="firefighter.flash"
Info: *******************************************************************
Info: Running Quartus II Convert_programming_file
Info: Command: quartus_cpf --no_banner --convert --device=EPCS128 --option=firef
ighter.opt c:/altera/91/quartus/work/firefight/firefighter.sof firefighter.pof
Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings
Info: Peak virtual memory: 75 megabytes
Info: Processing ended: Thu Sep 30 19:44:08 2010
Info: Elapsed time: 00:00:02
Info: Total CPU time (on all processors): 00:00:02
Info: Command: quartus_cpf --no_banner --convert firefighter.pof firefighter.rpd
Info: Peak virtual memory: 71 megabytes
Info: Processing ended: Thu Sep 30 19:44:11 2010
Info: Elapsed time: 00:00:03
Info: Total CPU time (on all processors): 00:00:02# Programming flash with the FPGA configuration
"$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --epcs --base=0x00011000 --cable='U
SB-Blaster [USB-1]' --sidp=0x00021048 --id=397621995 --timestamp=1285842295 --ac
cept-bad-sysid "firefighter.flash"
Using cable "USB-Blaster [USB-1]", device 1, instance 0x00
Resetting and pausing target processor: OK
Reading System ID at address 0x00021048: verified
No EPCS layout data - looking for section [EPCS-000000]
Leaving target processor paused# Creating .flash file for the project
"$SOPC_KIT_NIOS2/bin/elf2flash" --epcs --after="firefighter.flash" --input="code
.elf" --output="epcs_flash_controller_0.flash"# Programming flash with the project
cept-bad-sysid "epcs_flash_controller_0.flash"
What is the cause of this error?
Does the epcs base address you specify (--base=0x00011000) match the actual one as defined in sopc builder?
Have you programmed that epcs device before with a fpga configuration file? Are you sure it works?
