21615 Discussions
Unconstrained inputs/outputs
I just started to use the TimeQuest Timing Analyzer to constraint a new VHDL design (EP3C16). I managed to constraint my clock and derived clocks.
I have a process which is a state machine, where the states are changing based on some asynchronous IOs.
When I compile my project, I end-up with 'Unconstrained Input/Output Ports'. I went through the tutorials and am still confused on how to constrained those.
Let's say I have a state where I am waiting for an IO to go high to change to the next one (synchronous on the master clock). This input is coming from an external device Gumstix computer.
How should I constraint that input port?
Thank you for your help.
Mathieu
Have you read also the TQ user guide written by Rysc?
http://alterawiki.com/wiki/timequest_user_guide
I think what you need is explained very clearly here.
