21608 Discussions
Unusual message when using quartus_cdb commandline
Just wondering if I need to worry about this warning. My distributor said he had never seen it before:
$ quartus_cdb --update_mif LINX_SCLR.qpf
Info: *******************************************************************
Info: Running Quartus II 32-bit MIF/HEX Update
Info: Version 11.1 Build 173 11/01/2011 SJ Full Version
Info: Copyright (C) 1991-2011 Altera Corporation. All rights reserved.
Info: applicable agreement for further details.
Info: Processing started: Tue Dec 4 11:38:48 2012
Info: Command: quartus_cdb --update_mif LINX_SCLR.qpf
Warning (113015): Width of data items in "LocalRAM.hex" is greater than the memory width. Wrapping data items to subsequent addresses. Found 8800 warnings, reporting 10
Warning (113009): Data at line (2) of memory initialization file "LocalRAM.hex" is too wide to fit in one memory word. Wrapping data to subsequent addresses.
Warning (113009): Data at line (3) of memory initialization file "LocalRAM.hex" is too wide to fit in one memory word. Wrapping data to subsequent addresses.
Warning (113009): Data at line (4) of memory initialization file "LocalRAM.hex" is too wide to fit in one memory word. Wrapping data to subsequent addresses.
Warning (113009): Data at line (5) of memory initialization file "LocalRAM.hex" is too wide to fit in one memory word. Wrapping data to subsequent addresses.
Warning (113009): Data at line (6) of memory initialization file "LocalRAM.hex" is too wide to fit in one memory word. Wrapping data to subsequent addresses.
Warning (113009): Data at line (7) of memory initialization file "LocalRAM.hex" is too wide to fit in one memory word. Wrapping data to subsequent addresses.
Warning (113009): Data at line (8) of memory initialization file "LocalRAM.hex" is too wide to fit in one memory word. Wrapping data to subsequent addresses.
Warning (113009): Data at line (9) of memory initialization file "LocalRAM.hex" is too wide to fit in one memory word. Wrapping data to subsequent addresses.
Warning (113009): Data at line (10) of memory initialization file "LocalRAM.hex" is too wide to fit in one memory word. Wrapping data to subsequent addresses.
Warning (113009): Data at line (11) of memory initialization file "LocalRAM.hex" is too wide to fit in one memory word. Wrapping data to subsequent addresses.
Info (39024): Processed the following Memory Initialization File(s)
Info (39025): Processed Memory Initialization File /home/mkarasoff/devfiles/Clive/linxfpgawork/LINX_V4_2_b/LinxScalar/LINX_SCLR/LocalRAM.hex
Thanks for any advice.
