21610 Discussions
Using DDR SDRAM Controller
I have instantiated two DDR SDRAM controller. And when compiling my project by quartus, I found an error which highlights that the second controller pins were not assigned.
Q1: Can I use more DDR SDRAM Controller than one ?
Q2: How can I assign DDR SDRAM Controller pins?
Which DDR controller are you using? While creating the core, you designate the IO locations. So you can't create a single controller and use it twice, you have to create two separate controllers. I haven't read them completely, but this should help:
Legacy:
http://www.altera.com/literature/an/an392.pdf
Altmemphy:
http://www.altera.com/literature/an/an462.pdf
Thank you Rysc :)
