21615 Discussions
Using HIP PCIe from Cyclone V Development board to communicate to PC
I am trying to implement HIP PCIe in Cyclone V development board to communicate with a PC. In PC I have jungo driver installed.
In QSYS, I have instantiated:
1. PCIe_1x4 (Avalon Memory mapped) with one BAR (BAR0) set to 32-bit non-prefetchable memory and using 100 MHz. From this block, I have exported the following signals: refcllk, npor, hip_ctrl, reconfig_clk_locked, hip_serial, and hip_pipe. But the signal Txs is not connected to any where. The rest of the signals are: Rxm_BAR0, reconfig_to_xcvr, reconfig_busy, reconfig_from_xcvr and cra are connected to other blocks.
2. Transceiver Reconfiguration controller with number of reconfiguration interfaces: 5. reconfig_busy, mgmt_clk_clk, mgmt_rst_reset, reconfig_to_xcvr, and reconfig_from_xcvr are connected to other blocks and reconfig_mgmt is exported (it is not used any where)
  1. Clock source with 125 MHz taking from the development board (Y15 and AA15 diff pair) and clk_in_reset, I have assigned '1' (assuming always out of reset) to it at the top level.
4. PIO (Parallel I/O) with 32 bits as output.
Following are my connections:
  1. refclk from PCIe core is connected to pin W8 and, W7, which are differential pair from PC.
  2. coreclkout from PCIe core is feeding PIO clk.
  3. nreset_status from PCIe core is feeding PIIO reset.
  4. Rxm_BAR0 from PCIe core from PCIe is feeding Txs and cra in PCIe core also feeding PIO s1.
  5. reconfig_busy from XCVR_Reconfig is feeding reconfig_busy in PCIe core.
  6. reconfig_to_xcvr from XCVR_Reconfig is feeding reconfig_to_xcvr in PCIe core.
  7. reconfig_from_xcvr from XCVR_Reconfig is feeding reconfig_from_xcvr in PCIe core.
  8. clk from clock source is feeding mgmt_clk_clk in XCVR_Reconfig.
  9. clk_reset from clock source is feeding mgmt_rst_reset in XCVR_Recnfig.
I have generated the synthesis files and complied the code. When I download the sof file into FPGa in the development board there was no problem. Also using Jungo driver, I am able to see Altera device with VID 1172. Jungo driver can identify any changes I do between sof files.
But when I use Read/Write using address value for PIO base register (2000), Read returns FFFFFFFF and I I write different value to the same location re-read returns FFFFFF.
Does anybody know what am I doing wrong here?
Thank you all.
